查看: 1922|回复: 1
[求助] proe安装出错后没有正常安装补丁却可以用
发表于 2010-9-11 15:50 | 显示全部楼层 |阅读模式
proe4.0m040安装后出现这种错误,请指教!
我直接用的注册机生成license文件,就直接装了,后来发现还有补丁,然后就按照补丁说明
boot up your pc with windows
.start pro/e setup
.open ptc_licfile.dat with your fav txt-editor
.replace every occurance of 00-00-00-00-00-00 with the one shown in the bottom left corner of the Pro/e setup
(its your mac-id, format: xx-xx-xx-xx-xx)
.install pro/e - pro/m - pro/ds, i dont care which one or in which order
.on license-config screen select "nodelocked license" and point to edited ptc_licfile.dat
.blalala install
next for pro/engineer:
(if u didnt install the complete package, u get "missing file" errors, accept or bleed)
.run ptc.pro engineer.wildfire.5.0-patch.exe, point to <installdir>\i486_nt\obj folder
.edit <pro/e installdir>\bin\proev.bat
  change "%start_cmd% "%CGTECH_JRE%\bin\javaw" -Xms16m -Xmx64m -Xss4m -classpath "%CGTECH_CLASSES%;%CGTECH_CLASSES%\CGTech.jar" Vericut %argstr%" in
第一步没有做,直接做第二部,但是拷贝到OBJ后,PROVE.bat文件没有,后面都没有进行,然后运行PROE就可以了,请问我需要重新安装吗?
[ 本帖最后由 沪沽摩梭 于 2010-9-11 16:23 编辑 ]
1275
发表于 2010-9-11 21:40 | 显示全部楼层
运行常见错误 License request failed for feature PROE_DDiTy: -8 或 :-9  解决方法
GMT+8, 2025-4-20 04:02 , Processed in 0.133543 second(s), 25 queries .
