查看: 19296|回复: 13
[原创] 大家看这些折弯表,一看就是精华吧.靠自己编出来的
发表于 2010-8-25 10:47 | 显示全部楼层 |阅读模式
大家看这些折弯表,一看就是精华吧.靠自己编出来的!才是最好的!我这个好的公司用的哦!我们公司15位工艺的都用这个,但是不适合小折(Z折又叫段差)
设计的时候注意R角!第一份倒0角  展开才准   具体展开的补偿  请参照富士康或霍尼卡姆公司的 展开计算标准  三阶文件
!# Pro/TABLE
! [] S 92;
! [] W  8;
![A] W 10;
![B] W 10;
"!     90-Degree Bends - Required Straight Length of Stock (L)"
"! For Values of T and R outside the table range use the following,"
"FORMULA"
"IF (R>=0.25 & ANGLE==180)"
"        IF (T<1.5)"
"                L = (0.5*T+R)*ANGLE*PI/180"
"        ELSE"
"                L = (0.4*T+R)*ANGLE*PI/180"
"        ENDIF"
"ENDIF"
"IF (R<0.25 & ANGLE==180)"
"        IF (T<=0.3)"
"                L = 2*(R+T)"
"        ENDIF"
"        IF (T>0.3 & T<1.5)"
"                L = 2*R+1.6*T"
"        ENDIF"
"        IF (T>=1.5 & T<2.5)"
"                L = 2*R+1.65*T"
"        ENDIF"
"        IF (T>=2.5)"
"                L = 2*R+1.7*T"
"        ENDIF"
"ENDIF"
"IF (ANGLE<180)"
"        IF (R>3)"
"                IF (T<1.5)"
"                ELSE"
"                ENDIF"
"        ENDIF"
"        IF (R>2 & R<3)"
"                IF (T<1.5)"
"                        L = (0.5*T+3)*ANGLE*PI/180-2*(3-R)*TAN(ANGLE/2)"
"                ELSE"
"                        L = (0.4*T+3)*ANGLE*PI/180-2*(3-R)*TAN(ANGLE/2)"
"                ENDIF"
"        ENDIF"
"        IF (R<=2)"
"                IF (T<=0.3)"
"                        IF (ANGLE<=150)"
"                                L = 2*R*TAN(ANGLE/2)"
"                        ENDIF"
"                        IF (ANGLE>150)"
"                        ENDIF"
"                ENDIF"
"                        L = 0.4*T*ANGLE/90+2*R*TAN(ANGLE/2)"
"                ENDIF"
"                        L = 0.35*T*ANGLE/90+2*R*TAN(ANGLE/2)"
"                ENDIF"
"                IF (T>=2.5)"
"                        L = 0.3*T*ANGLE/90+2*R*TAN(ANGLE/2)"
"                ENDIF"
"        ENDIF"
"ENDIF"
"END FORMULA"
"! This table is valid for the following materials"
"START MATERIALS"
"GI"
"SGCC"
"SECC"
"CRS"
"SPTE"
"SUS"
"END MATERIALS"
"TABLE"
"!                            INSIDE  RADIUS (R)"
" " 0
"!THICKNESS  (T)"
100
 楼主| 发表于 2010-8-25 10:47 | 显示全部楼层
pro713 该用户已被删除
发表于 2010-8-25 11:58 | 显示全部楼层
发表于 2010-8-25 14:06 | 显示全部楼层
什么?
发表于 2010-8-25 15:19 | 显示全部楼层
顶一下
发表于 2011-11-23 15:47 | 显示全部楼层
厉害啊!分享了!!!
发表于 2019-9-7 12:33 | 显示全部楼层
朋友,上传一个表更好! 特意复制一串代码很多人编辑会有错误的~帮人诚心一点嘛..
发表于 2020-2-27 08:34 | 显示全部楼层
路过了顶一下
发表于 2020-6-12 09:48 | 显示全部楼层
厉害啊!分享了!!!
发表于 2020-10-26 15:10 | 显示全部楼层
顶一下不错不错
GMT+8, 2025-4-19 20:53 , Processed in 0.128916 second(s), 28 queries .
