查看: 4491|回复: 3
[求助] 请帮忙译一下V5.0 M020的安装说明
发表于 2010-2-18 12:21 | 显示全部楼层 |阅读模式
看了下M010的安装方法,试着安了下M020的,但在破解时和M010有些不同,下面是英文的安装说明,请大家给准确点译下,谢谢了
.boot up your pc with windows
.start pro/e setup
.open ptc_licfile.dat with your fav txt-editor
.replace every occurance of 00-00-00-00-00-00 with the one shown in the bottom left corner of the Pro/e setup
(its your mac-id, format: xx-xx-xx-xx-xx)
.install pro/e - pro/m - pro/ds, i dont care which one or in which order
.on license-config screen select "nodelocked license" and point to edited ptc_licfile.dat
.blalala install
next for pro/engineer:
(if u didnt install the complete package, u get "missing file" errors, accept or bleed)
.run ptc.pro engineer.wildfire.5.0-patch.exe, point to <installdir>\i486_nt\obj folder
.edit <pro/e installdir>\bin\proev.bat
  change "%start_cmd% "%CGTECH_JRE%\bin\javaw" -Xms16m -Xmx64m -Xss4m -classpath "%CGTECH_CLASSES%;%CGTECH_CLASSES%\CGTech.jar" Vericut %argstr%" in
        "%start_cmd% "%CGTECH_JRE%\bin\javaw" -Xms16m -Xmx64m -Xss4m -classpath "%CGTECH_CLASSES%;%CGTECH_CLASSES%\CGTech.jar" Vericut %argstr% PTC_KEY=0"
(add PTC_KEY=0)
pro/mechanica:
.run ptc.pro mechanica.wildfire.5.0-patch.exe
.point to <pro/m installdir>\i486_nt\bin
                                         <pro/m installdir>\i486_nt\obj
                                         <pro/m installdir>\i486_nt\ptc
(in this order, after every "missing file" error)
pro/distributed services:
.run ptc.distributed.services.5.0-patch.exe and point to <pro/ds installdir>\i486_nt\obj
发表于 2010-2-18 12:45 | 显示全部楼层
        按照“野火”先生的专题图文教程进行安装是最可靠的途径:
       【proe wildfire 5.0 M010,M020 野火版正式版安装步骤图解教程(含mechanic安装)】,
        http://www.proewildfire.cn/thread-32988-1-1.html
P.S. :
        楼主发出的求助英文原稿,对于有安装经验者甚易跟进,但并不足以引导众多新手取得安装的成功。
        上述“野火”先生的专题图文教程才是最周详的指南,惟此可取,绝然再无出其右者!
[ 本帖最后由 yun0336wu 于 2010-2-18 12:46 编辑 ]
 楼主| 发表于 2010-2-18 14:40 | 显示全部楼层
我就是按那个安装成功的,但是破解的不太完美,因为破解文件和M010的是不一样的,而且在破解时找不到目录,不知是不是我错在哪里了,自认为上面的英语大部分也能懂,上面的贴子链接是M010的安装方法,与M020还是有区别的
 楼主| 发表于 2010-2-18 14:48 | 显示全部楼层
(add PTC_KEY=0)
就是这里面不太明白,编辑PROE安装目录下\bin\proev.bat,而在这个目录下就不存在这样的文件
还有最后面的pro/ds installdir目录是哪一个,只有个简写的路径,ds安装目录也没找到,完全的文件夹名是什么,是指的dsrc这个文件夹吗
GMT+8, 2024-11-17 00:55 , Processed in 0.131888 second(s), 27 queries .
