查看: 9624|回复: 5
[已解决] adams与proe的连接
发表于 2009-9-8 16:07 | 显示全部楼层 |阅读模式
各位学长们,务必帮忙啊!我已经按照步骤装上了mechpro2005了,而且proe中已经显示出了mechproe的模块,但是运行时有这样的错误
ADAMSD_LICENSE_FILE=UNDEFIND
MSC_LICENSE_FILE=1700@TT
MSC_LIC_PREF=1
MECHANISM/PRO License feature name:ADAMS_MECHPRO
ERROR: Cannot get a license to run MECHANISM/PRO on this CPU.
这是怎么会事啊?
请务必赐教啊,先谢谢各位了!
发表于 2009-9-8 17:01 | 显示全部楼层
回复 楼主 tntyoyo1983 的帖子
您的安装可能不完整,而导致解密没完成。
ADAMSD_LICENSE_FILE没找到,不能提供 license 使您的处理器运行这个软件。
请检查您的源文件、安装和解密问题!
二,您装的是什么版本的ADAMS,俺装的时候也曾经遇到这种情况(ADAMS是2007的。)
后来改为下载安装了ADAMS2005就搞定了。建议您试试!
请注意下面这个说明:
Types of Licensing
You can select two types of licensing for MECHANISM/Pro. You select the method depending on the method your MSC.ADAMS products use:
.For MSC.ADAMS 2003, the selections are as follows:
ADAMS--Select if MSC.ADAMS 2003 used the standard MSC.ADAMS licensing.
MSC--Select if MSC.ADAMS 2003 transitioned to MSC.Master Key (referred to as Campus Licensing in 2003), a token-based licensing system.
.For MSC.ADAMS 2005, the transition to MSC licensing was complete. Therefore, if you are using MSC.ADAMS 2005, you have only one selection, MSC.
Ways to Retrieve Licensing
There are two ways to retrieve licensing information for MECHANISM/Pro:
.From a File--You input a path to a license file, authorizing the use of your MSC.ADAMS products, including MECHANISM/Pro. It is a non-server, node-locked license.
.License Server--If you created a license server for MSC.ADAMS products, you can use it to manage the licensing for MECHANISM/Pro. A license server manages the licensing for many installations of MSC.ADAMS products, including MECHANISM/Pro. For information about creating a license server, see the installation guides that come with MSC.ADAMS.
认真阅读不难发现问题了。
具体做法是ADAMS2005的用户一定选择msc license的license type;而得到license的方式(retrieve license)一定要选择License Server;其他就按破解文件的说明进行就好了。
以上希望对您有所帮助 !
[ 本帖最后由 yun0336wu 于 2009-9-8 17:14 编辑 ]
 楼主| 发表于 2009-9-8 19:41 | 显示全部楼层
高人,太感谢了!能留个QQ吗?想跟您交流一下。
发表于 2009-9-8 22:21 | 显示全部楼层
要是按2楼搞定了,请回帖明确说明下
 楼主| 发表于 2009-9-9 08:26 | 显示全部楼层
我现在用的的确是adams2007版的,我也怀疑可能是版本问题。现在已经下载了adams的2005版了,问题正在解决中。解决了一定明确说明。我觉得二楼学长说的很有道理。
 楼主| 发表于 2009-9-9 09:35 | 显示全部楼层
问题已经解决了,我装了adams2005就可以用了。谢谢学长了
GMT+8, 2024-11-23 09:06 , Processed in 0.157763 second(s), 25 queries .
