楼主: cxh123
[原创] 关于Creo8.0和9.0的映射键问题!
 楼主| 发表于 2022-5-6 16:47 | 显示全部楼层
voice 发表于 2022-5-6 16:44
你确定?这个可跟creo无关啊,这是windows系统bat程序,不可能删不掉吧,我都测试了可以
是的,你是5.0或6.0的吧,我用8.0和9.0都测试过几遍,还是只能对当前工作目录有效,对下面的子文件夹还是不行的,可能新版本不支持了吧
发表于 2022-5-7 11:08 | 显示全部楼层
我也试了,的确不能删除子文件夹的文件了。不知道为啥?等待大佬解决。
 楼主| 发表于 2022-5-24 10:36 | 显示全部楼层
还是没有大佬解决的呢
发表于 2022-5-26 11:59 | 显示全部楼层
我调用vbs,不会弹黑窗
发表于 2022-5-26 12:01 | 显示全部楼层
wscript.sleep 100
on error resume next
'关闭cmd窗口
set proglist = getobject("winmgmts:\\.\root\cimv2").execquery("select * from win32_process")
for each prog in proglist
if lcase(prog.name) = "cmd.exe" then
createobject("wscript.shell").run "taskkill /im cmd.exe /f" '关闭cmd窗口
exit for
end if
next
set i = createobject("scripting.filesystemobject")
l = "e:\00\*."
i.deletefile l &"inf*"
i.deletefile l &"log.*"
i.deletefile l &"xas*"
i.deletefile l &"crc*"
i.deletefile l &"sec*"
i.deletefile l &"dwl*"
i.deletefile l &"drw*"
i.deletefile l &"xml*"
i.deletefile l &"ger*"
i.deletefile l &"ers*"
i.deletefile l &"err*"
i.deletefile l &"out*"
i.deletefile l &"tst*"
i.deletefile l &"pls*"
i.deletefile l &"idx*"
i.deletefile l &"dbt*"
i.deletefile l &"acc*"
i.deletefile l &"trail*"
i.deletefile l &"tmp*"
i.deletefile l &"xpr*"
i.deletefile l &"m_p*"
i.deletefile l &"bom*"
l = "e:\00\*"
i.deletefile l &"prt000*"
i.deletefile l &"error.chk"
i.deletefile l &"cfgerror.txt.*"
i.deletefile l &"outdated.lst.*"
i.deletefile"e:\00\regen_backup_model00*"
i.deletefile"e:\Creo-CAD\*.log.*"
i.deletefile"e:\Creo-CAD\current_session.pro"
i.deletefile"e:\Creo-CAD\creo_parametric_customization.ui"
GMT+8, 2025-4-22 18:37 , Processed in 0.134725 second(s), 20 queries .
