查看: 33866|回复: 43
[分享] 分享BUW.EMX.14.0.1.0.for.Creo.8.0
发表于 2021-8-16 12:29 | 显示全部楼层 |阅读模式
如题,分享BUW.EMX.14.0.1.0.for.Creo.8.0,追新版本的可以下载咧。
分享地址如下:
                链接:https://pan.baidu.com/s/137rBjonMUEfjKFwIUHKy5w
                提取码:5hc9
话说,各位顺手回复一下呗,非要整个回复可见什么的太劳什子了。
以下发更新内容描述:
Changelog
14.0.1.0
Enhancements
Add STRACK OXA plate size.
Add new Hasco components [RM-10793]: Z98HT, Z21, Z031, Z032, Z811HT, Z4501, Z458.
Update existing Hasco components: Z03, Z11, Z40, Z43, Z50, Z81, Z511, Z555, Z556, Z557, Z691, Z721, Z725, Z811, Z051, Z94, Z942, Z1212, Z1213, Z185, Z9430.
Remove obsolete Hasco components: K100, K1000, K107, K500, K501, K505, K506, TD(tubular dowel)
Add missing Meusburger cooling component E2101. [RM-10520]
Improvements
Show Library Component Dialog again in case assemby references are not yet fully defined and user select OK button. [RM-11675]
Bugfixes
Issue fixed: Missing translations in BOM column names. [SPR-12814097] [RM-11863]
Issue fixed: Copy drawing will not ignore for plates if option EMX_CHECK_DWG_TYPES is set to "-". [RM-11674]
Issue fixed: The assembly of the ejectors fails with different assembly directions for a reference part with the error "Cannot assemble the cutouts.". [RM-11559] [SPR-1241162]
Issue fixed: Balloons can not be placed within local sections on drawing views. [RM-12050]
Issue fixed: ibrary component fails to cut one of the parts. [RM-11393]
Issue fixed: Message, which tells user that a guide or screw diameter is different compared to required diameter in moldbase defintion, is not informative. [RM-12088]
Issue fixed: In case udf group is part of refrence pattern and leader group is not inside of model, UDF gets deleted while modifying component (e.g. second rail model) [RM-12087]
14.0.0.0
Improvements
Major Release
Supports Creo 8.0
参与人数 1威望 +1 金钱 +6 收起 理由
野火 + 1 + 6 感谢分享
发表于 2021-8-16 14:47 | 显示全部楼层
对,这样才好嘛;尽管我也不用
发表于 2021-8-16 15:15 | 显示全部楼层
尽管我也不用,这样做非常好;
VIP 勋章希望之星勋章热心助人勋章
发表于 2021-8-16 17:13 | 显示全部楼层
感谢分享!!
发表于 2021-8-16 17:31 | 显示全部楼层
感谢楼主分享,来支持一下
发表于 2021-8-17 11:03 | 显示全部楼层
发表于 2021-8-18 11:01 | 显示全部楼层
现在有没有支持CREO8.0的EMX的版本
发表于 2021-8-18 14:07 | 显示全部楼层
能用,好评C:\Users\CONTROL\Desktop
发表于 2021-8-18 14:09 | 显示全部楼层
 楼主| 发表于 2021-8-18 16:16 | 显示全部楼层
这个就是了
GMT+8, 2025-4-22 21:03 , Processed in 0.124617 second(s), 30 queries .
