查看: 47227|回复: 69
[分享] 来一本Creo的英文教程
发表于 2019-6-21 11:31 | 显示全部楼层 |阅读模式
Computer Aided Virtual Manufacturing Using Creo Parametric
Providing a step-by-step guide for the implementation of virtual manufacturing using Creo Parametric software (formerly known as Pro-Engineer), this book creates an engaging and interactive learning experience for manufacturing engineering students.
Featuring graphic illustrations of simulation processes and operations, and written in accessible English to promote user-friendliness, the book covers key topics in the field including: the engraving machining process, face milling, profile milling, surface milling, volume rough milling, expert machining, electric discharge machining (EDM), and area turning using the lathe machining process.
Maximising reader insights into how to simulate material removal processes, and how to generate cutter location data and G-codes data, this valuable resource equips undergraduate, postgraduate, BTech and HND students in the fields of manufacturing engineering, computer aided design (CAD) and computer aided engineering (CAE) with transferable skills and knowledge. This book is also intended for technicians, technologists and engineers new to Creo Parametric software.
链接:https://pan.baidu.com/s/1OQOWm5n_JVSk4x1_Fahvsw
游客,如果您要查看本帖隐藏内容请回复
韬光养晦
发表于 2019-6-21 13:18 | 显示全部楼层
发表于 2019-6-21 18:49 | 显示全部楼层
没法看,自己收藏吧
发表于 2019-6-21 20:05 | 显示全部楼层
看个新鲜吧,谢谢。
亚历山大
发表于 2019-6-21 20:48 | 显示全部楼层
看看
发表于 2019-6-22 00:22 | 显示全部楼层
谢谢分享!
发表于 2019-6-22 00:56 | 显示全部楼层
谢谢
热心助人勋章优秀会员勋章希望之星勋章嘉宾勋章
发表于 2019-6-22 05:29 | 显示全部楼层
感谢分享
发表于 2019-6-23 10:33 | 显示全部楼层
我只是想看看自己是否可无障碍读下去。
GMT+8, 2025-4-20 02:12 , Processed in 0.118134 second(s), 22 queries .
