查看: 4464|回复: 5
[求助] PDX11安装creo5.0方法哪位大神有啊?
发表于 2019-3-26 17:13 | 显示全部楼层 |阅读模式
PDX11安装creo5.0方法哪位大神有啊?不知道怎么安装。。。
1272
发表于 2019-3-26 21:02 | 显示全部楼层
安装包里有说明的吧,这个和你版本不一样,可以参考下
To use this application you need PTC Creo Parametric 2.0-4.0 with SSQ's crack to be preinstalled!
1. Install PTC Creo PDX 10.0 M030
2. To connect Creo PDX 10.0 M030 to PTC Creo Parametric
For Creo Parametric 2.0
Open in text editor and copy all strings from file "<PDX 10.0 progdir>\bin\creo2\config.pro" to file "<Creo 2.0 progdir>\..\config.pro"
For Creo Parametric 3.0
Open in text editor and copy all strings from file "<PDX 10.0 progdir>\bin\creo3\config.pro" to file "<Creo 3.0 progdir>\..\config.pro"
For Creo Parametric 4.0
Open in text editor and copy all strings from file "<PDX 10.0 progdir>\bin\creo4\config.pro" to file "<Creo 4.0 progdir>\..\config.pro"
Note: Also you can connect Creo PDX 10.0 to PTC Creo Parametric using standard Creo tool:
Utilities > Auxiliary Application > Register.. (browse to proper protk.dat in <PDX 10.0 program folder>\bin\creo2 or <PDX 10.0 program folder>\bin\creo3 or <PDX 10.0 program folder>\bin\creo4 ) > Open > Start
TeAM SolidSQUAD-SSQ
 楼主| 发表于 2019-3-27 09:03 | 显示全部楼层
To use this application you need PTC Creo Parame ...
没看懂
发表于 2019-6-7 17:55 | 显示全部楼层
说实话,我也没看太懂
发表于 2019-6-8 13:04 | 显示全部楼层
2楼大佬给的安装说明很详细了,如果还看不懂的话,呵呵。。。。。。 PDX也学不会的
发表于 2020-5-21 16:27 | 显示全部楼层
PDX11那里可以下载呀
GMT+8, 2024-11-17 03:50 , Processed in 0.108572 second(s), 27 queries .
