查看: 5316|回复: 2
[求助] 如何将编好的菜单和对话框联系起来,即从菜单按钮打开UI对话框
发表于 2018-4-15 21:09 | 显示全部楼层 |阅读模式
比如这种这是菜单程序:
static uiCmdAccessState AccessDefault(uiCmdAccessMode access_mode)
        return(ACCESS_AVAILABLE);
void Test1()
        AfxMessageBox(_T("测试按钮A"));
void Test2()
        AfxMessageBox(_T("测试按钮B"));
extern "C" int user_initialize()
        ProError status;
        ProFileName  MsgFile;
        ProStringToWstring(MsgFile, "IconMessage.txt");  //注意此处的IconMessage与后面的text文件夹下的IconMessage.txt文件名必须相同
        uiCmdCmdId PushButton1_cmd_id,PushButton2_cmd_id;
        status=ProMenubarMenuAdd("MainMenu","Function","Help",PRO_B_TRUE,MsgFile);
        ProCmdActionAdd("PushButton1_Act",(uiCmdCmdActFn)Test1,12,AccessDefault,PRO_B_TRUE,PRO_B_TRUE,&PushButton1_cmd_id);
        ProMenubarmenuPushbuttonAdd("MainMenu","PushButton","FirstButton","this button will show a message",NULL,PRO_B_TRUE,PushButton1_cmd_id,MsgFile);
        ProCmdActionAdd("PushButton2_Act",(uiCmdCmdActFn)Test2,uiCmdPrioDefault,AccessDefault,PRO_B_TRUE,PRO_B_TRUE,&PushButton2_cmd_id);
        ProMenubarmenuPushbuttonAdd("MainMenu", "PushButton2", "SecondButton", "this button will show a message", NULL, PRO_B_TRUE, PushButton2_cmd_id, MsgFile);
        return status;
extern  "C" void user_terminate()
        AFX_MANAGE_STATE(AfxGetStaticModuleState());
注册运行点击菜单可以显示:测试按钮A/B,但如何改动才能将编好的对话框打开
发表于 2018-4-16 11:24 | 显示全部楼层
void Test1()
在这里面写你要的自定义窗口啊
 楼主| 发表于 2018-4-16 19:13 | 显示全部楼层
就是不知道自定义窗口怎么用,我的对话框文件是:window_1.res
对话框调用动作函数文件是:window1
可是AfxMessageBox好像只能用于弹出对话,难道还有其它函数用于打开对话框文件的?
麻烦你了,谢谢
GMT+8, 2025-11-5 22:00 , Processed in 0.129652 second(s), 23 queries .
