查看: 5042|回复: 0
[原创] vba cad批量转pdf文件代码
发表于 2017-9-30 09:02 | 显示全部楼层 |阅读模式
'打印pdf
Sub printf()
Dim name As String
Dim num As Integer
num = 0
name = Dir("E:\*.dwg", vbNormal)
Do Until name = ""
'Application.Documents.Open
Application.Documents.Open ("E:\" & name)
Call openf
ThisDrawing.Application.Documents(0).Close False
num = num + 1
name = Dir
Loop
Debug.Print num
End Sub
'打印设置
Sub openf()
ThisDrawing.ActiveLayout.PlotType = acExtents
ThisDrawing.ActiveLayout.StandardScale = acScaleToFit
ThisDrawing.ActiveLayout.CenterPlot = True
ThisDrawing.ActiveLayout.PlotRotation = ac90degrees
ThisDrawing.ActiveLayout.StyleSheet = "monochrome.ctb"
ThisDrawing.ActiveLayout.PlotWithLineweights = False
ThisDrawing.ActiveLayout.PlotWithPlotStyles = True
ThisDrawing.Application.ActiveDocument.SetVariable "BACKGROUNDPLOT", 0           '把文件传给打印机队列
ThisDrawing.Plot.PlotToDevice ("Adobe PDF.pc3")
End Sub
GMT+8, 2024-11-25 12:54 , Processed in 0.127201 second(s), 20 queries .
