查看: 5642|回复: 3
[求助] PTC_Creo_3.0_M010_Win32&64位 物理地址也是对的,应该是license 的问题
发表于 2017-6-15 23:15 | 显示全部楼层 |阅读模式
安装新下载的  PTC_Creo_3.0_M010_Win32&64位  物理地址也是对的,应该是license 的问题,麻烦看看
有懂的帮忙解答下什么问题
谢谢
发表于 2017-6-16 08:14 | 显示全部楼层
1. Open "ptc_licfile.dat" in text editor and replace 00-00-00-00-00-00 in every-feature with your computer real hostid
2. Save edited "ptc_licfile.dat" on your computer
3. Create system environment variable PTC_D_LICENSE_FILE=<full path to ptc_licfile.dat>
4. Install PTC Creo 3.0 M050. In Licensing window if there is no path to ptc_licfile.dat in field "License Summary > Source" just drug-and drop ptc_licfile.dat in that field
5. Run "PTC_Creo_Patcher_0.1_SSQ.exe" (on Vista/Win7/Win8 computers be sure to run it as Administrator).
Click "Look For..", browse to <Creo 3.0 progdir>\M050\Common Files\ (by default C:\Program Files\PTC\Creo 3.0\M050\Common Files\) and click "Look For.." once again
Click "Start" and wait for patcher info window "All files seem to be patched. Enjoy!"
Click "OK"
6. If you have installed PTC Creo 3.0 M050 Distributed Services Manager
Click "Look For..", browse to <Creo 3.0 Distributed Services Manager progdir> (by default C:\Program Files\PTC\Creo 3.0\Distributed Services Manager\) and click "Look For.." once again
Click "OK"
7. If you have installed Mathcad Prime 3.1 M050
Click "Look For..", browse to <Mathcad Prime 3.1 progdir> (by default C:\Program Files\PTC\Mathcad Prime 3.1\) and click "Look For.." once again
Click "OK"
8. Close "PTC_Creo_Patcher_SSQ"
9. Enjoy
你好,你的Creo 3.0应该是没有破解好,附件是破解文件。另外,请参照以上说明进行破解。我的也是这样顺利安装好的。希望能帮到你。谢谢!
Cracked by Team-SolidSQUAD
PTC_Creo_Patcher_0.1_SSQ.rar
330.06 KB, 下载次数: 40
发表于 2017-6-16 23:25 | 显示全部楼层
运行常见错误 License request failed for feature PROE_DDiTy: -8 或 :-9  解决方法
(出处: 野火论坛)
 楼主| 发表于 2017-6-19 20:36 | 显示全部楼层
谢谢大家的支持,已经结局了
GMT+8, 2025-2-4 04:43 , Processed in 0.142928 second(s), 28 queries .
