查看: 6671|回复: 5
[求助] 用PROE5.0的配置文件接 Creo2.0字体都加粗了是怎么回事?
发表于 2016-4-22 21:57 | 显示全部楼层 |阅读模式
用PROE5.0的配置文件config 接 Creo2.0  其他都好,就是工程图打印出图纸尺寸值、文本注解、名称、图号、材料字体都加粗了是怎么回事??用5.0又没关系!
! == For complete descriptions see ==
! == FUNDAMENTALS User Guide. ==
!Model unit setup
pro_unit_length UNIT_MM
pro_unit_mass UNIT_KILOGRAM
! Drawing & format setup files
drawing_setup_file d:\ptc5.0\config\draw_rd.dtl
format_setup_file d:\ptc5.0\config\draw_rd.dtl
pro_format_dir D:\ptc5.0\config\format
pro_sheet_met_dir D:\ptc5.0\config\table\table-ky.bnd
pro_symbol_dir d:\ptc5.0\config\symbol
trail_dir d:\ptc5.0\config\trail
pen_table_file d:\ptc5.0\config\table\table.pnt
display HIDDENVIS
tangent_edge_display no
pdf_use_pentable yes
symbol_instance_palette_file D:\ptc5.0\config\symbol\biaozhunmoban.drw
rename_drawings_with_object both
create_drawing_dims_only yes
mass_property_calculate automatic
dim_inactive_components never
allow_refs_to_geom_reps_in_drws yes
dxf_out_scale_views YES
dxf_out_drawing_scale yes
!Tolerence Setup
tol_display no
tol_mode nominal
tolerance_standard ISO
!Layer Setup
def_layer layer_DATUM DATUM
def_layer layer_AXIS AXIS
def_layer LAYER_CSYS CSYS
def_layer LAYER_POINT POINT
def_layer LAYER_CURVE CURVE
def_layer LAYER_QUILT QUILT
!Plotter setup
! Use Windows printer manager
! as the default printer driver.
plotter_command WINDOWS_PRINT_MANAGER
pro_plot_config_dir D:\ptc5.0\config\table
raster_plot_dpi 300
plot_linestyle_scale 1
use_software_linefonts yes
display_axes no
display_axis_tags no
display_coordinate_sys no
display_planes yes
display_plane_tags yes
datum_display no
datum_point_display no
default_font simfang1
! System environment
highlight_new_dims YES
parenthesize_ref_dim yes
system_edge_high_color 100 100 0
allow_old_style_round yes
bell NO
info_output_format text
bom_format D:\ptc5.0\config\templates\rdbom.fmt
!=====Sketcher Set=======
sketcher_intent_manager Yes
sketcher_disp_constraints Yes
sketcher_disp_dimensions Yes
!DEC PLACE
default_dec_places 2
template_designasm D:\ptc5.0\config\templates\mmns_asm_design_rd.asm
template_sheetmetalpart D:\ptc5.0\config\templates\mmns_part_sheetmetal_rd.prt
template_solidpart D:\ptc5.0\config\templates\mmns_part_solid_rd.prt
template_drawing D:\ptc5.0\config\templates\rd_drawing.drw
allow_anatomic_features yes
reserved_menu_space 1
set_menu_width 20
menu_translation yes
nccheck_type nccheck
save_drawing_picture_file both
ncpost_type gpost
pro_unit_sys mmns
pro_dtl_setup_dir d:\ptc5.0\config
pro_colormap_path d:\ptc5.0\config
allow_confirm_window yes
hole_diameter_override no
system_colors_file D:\ptc5.0\config\syscol.scl
multiple_skeletons_allowed yes
intf_out_layer part_layer
override_store_back yes
save_objects changed
menu_show_instances no
!mapkey
mapkey dwg @MAPKEY_LABEL保存CAD;~ Command `ProCmdModelSaveAs` ;\
mapkey(continued) ~ Close `main_dlg_cur` `adbFile_cb`;~ Open `file_saveas` `type_option`;\
mapkey(continued) ~ Close `file_saveas` `type_option`;\
mapkey(continued) ~ Select `file_saveas` `type_option`1  `db_560`;\
mapkey(continued) ~ Activate `file_saveas` `OK`;~ Activate `export_2d_dlg` `LogWin_Button`0 ;\
mapkey(continued) ~ Activate `export_2d_dlg` `OK_Button`;~ Activate `UI Message Dialog` `ok`;
mapkey sa @MAPKEY_LABEL保存;~ Command `ProCmdViewRefit` ;\
mapkey(continued) ~ Command `ProCmdModelSave` ;~ Close `main_dlg_cur` `adbFile_cb`;\
mapkey a4 @MAPKEY_LABEL打印A4;~ Command `ProCmdModelPrint` ;\
mapkey(continued) ~ Close `main_dlg_cur` `adbFile_cb`;~ Select `print_config` `CascadeButton1`;\
mapkey(continued) ~ Close `print_config` `CascadeButton1`;~ Activate `print_config` `打印A4配置`;\
mapkey(continued) ~ Close `print_config` `CascadeButton1`;~ Activate `print_config` `OK`;
mapkey a3 @MAPKEY_LABEL打印A3;~ Command `ProCmdViewRefit` ;\
mapkey(continued) ~ Command `ProCmdModelPrint` ;~ Close `main_dlg_cur` `adbFile_cb`;\
mapkey(continued) ~ Select `print_config` `CascadeButton1`;\
mapkey(continued) ~ Close `print_config` `CascadeButton1`;~ Activate `print_config` `打印A3配置`;\
mapkey 2d @MAPKEY_LABEL从3D到2D;\
mapkey(continued) ~ Trail `UI Desktop` `UI Desktop` `PREVIEW_POPUP_TIMER` \
mapkey(continued) `main_dlg_w3HTLeft.AssyTree:<NULL>`;~ Command `ProCmdModelNew` ;\
mapkey(continued) ~ Select `new` `Type`1  `Drawing`;\
mapkey(continued) ~ Activate `new` `chk_use_default_template`0 ;@MANUAL_PAUSE输入图号;\
mapkey(continued) ~ Activate `new` `OK`;~ Select `dwg_create` `rad_format`1  `2`;\
mapkey(continued) ~ Activate `dwg_create` `psh_format_browse`;\
mapkey(continued) ~ Trail `UI Desktop` `UI Desktop` `DLG_PREVIEW_POST` `file_open`;\
mapkey(continued) `file_openh_list.Filelist:<NULL>`;@MANUAL_PAUSE选择图框;\
mapkey(continued) ~ Activate `file_open` `Open`;~ Activate `dwg_create` `psh_ok`;\
mapkey(continued) ~ Timer `UI Desktop` `UI Desktop` `popupMenuRMBTimerCB`;\
mapkey(continued) ~ Command `ProCmdDwgViewGen` ;@PAUSE_FOR_SCREEN_PICK;\
mapkey(continued) ~ Select `drawing_view` `view_names_list`1  `FRONT`;\
mapkey(continued) ~ Activate `drawing_view` `psh_apply`;\
mapkey(continued) ~ Select `drawing_view` `options_list`1  `ViewDisp`;\
mapkey(continued) ~ Open `drawing_view` `disp_style_rad`;\
mapkey(continued) ~ Close `drawing_view` `disp_style_rad`;\
mapkey(continued) ~ Select `drawing_view` `disp_style_rad`1  `nohidden`;\
mapkey(continued) ~ Open `drawing_view` `tang_edge_rad`;~ Close `drawing_view` `tang_edge_rad`;\
mapkey(continued) ~ Select `drawing_view` `tang_edge_rad`1  `none`;\
mapkey(continued) ~ Activate `drawing_view` `psh_ok`;
mapkey bb @MAPKEY_LABEL创建球标;\
mapkey(continued) ~ Activate `main_dlg_cur` `page_Table_control_btn`0 ;\
mapkey(continued) ~ Command `ProCmdDwgTblBomBalloons` ;#CREATE BALLOON;#BY COMP;#COMP & VIEW;\
mapkey(continued) @PAUSE_FOR_SCREEN_PICK;@PAUSE_FOR_SCREEN_PICK;#DONE;
mapkey mo @MAPKEY_LABEL重命名;~ Command `ProCmdModelRename` ;\
mapkey(continued) ~ Select `rename` `ph_model.cb`;~ Close `rename` `ph_model.cb`;\
mapkey(continued) ~ Activate `rename` `Select`;~ Close `rename` `ph_model.cb`;
mapkey DM @MAPKEY_LABEL尺寸修改;~ Select `main_dlg_cur` `MenuBar1`1  `Edit`;\
mapkey(continued) ~ Select `main_dlg_cur` `Edit.cbSelect`;~ Close `main_dlg_cur` `MenuBar1`;\
mapkey(continued) ~ Close `main_dlg_cur` `Edit.cbSelect`;~ Activate `main_dlg_cur` `pshAll`;\
mapkey(continued) ~ Select `main_dlg_cur` `MenuBar1`1  `Sketch`;\
mapkey(continued) ~ Select `main_dlg_cur` `Sketch.cbDimension`;\
mapkey(continued) ~ Close `main_dlg_cur` `Sketch.cbDimension`;\
mapkey(continued) ~ Select `main_dlg_cur` `MenuBar1`1  `Insert`;\
mapkey(continued) ~ Select `main_dlg_cur` `MenuBar1`1  `View`;\
mapkey(continued) ~ Select `main_dlg_cur` `MenuBar1`1  `Edit`;\
mapkey(continued) ~ Close `main_dlg_cur` `MenuBar1`;\
mapkey(continued) ~ Activate `main_dlg_cur` `Edit.chkModify`1 ;~ FocusOut `ui_dynmod` `in.0`;
mapkey in @MAPKEY_LABEL重复;~ Command `ProCmdRepeat`;
mapkey th @MAPKEY_LABEL替换绘图参数及图框;~ Command `ProCmdDrwSetup` ;\
mapkey(continued) ~ Close `main_dlg_cur` `adbFile_cb`;~ FocusOut `preferences` `InputOpt`;\
mapkey(continued) ~ Activate `preferences` `Open`;\
mapkey(continued) ~ Select `file_open` `Ph_list.List_table`1  `draw_rd.dtl`;\
mapkey(continued) ~ Activate `file_open` `Open`;~ Activate `preferences` `ok`;\
mapkey(continued) ~ Command `ProCmdDwgPageSetup` ;~ Close `main_dlg_cur` `adbFile_cb`;\
mapkey(continued) ~ Arm `pagesetup` `TblFormats`2  `1` `fmt`;\
mapkey(continued) ~ Select `pagesetup` `TblFormats`2  `1` `fmt`;\
mapkey(continued) ~ Open `pagesetup` `TblFormats_INPUT`;~ Close `pagesetup` `TblFormats_INPUT`;\
mapkey(continued) ~ Select `pagesetup` `TblFormats_INPUT`1  `Browse...`;\
mapkey(continued) `file_openh_list.Filelist:<NULL>`;\
mapkey(continued) ~ Select `file_open` `Ph_list.Filelist`1  `ky-a4.frm`;@MANUAL_PAUSE选好图框后按确定;\
mapkey(continued) ~ Activate `file_open` `Open`;~ Activate `pagesetup` `OK`;\
mapkey(continued) ~ Activate `keep_format_tables` `RemoveAll`;~ Activate `0_std_confirm` `OK`;\
mapkey(continued) A        0        1;;~ Command `ProCmdViewRefit` ;\
mapkey cc @MAPKEY_LABEL复制并粘贴;~ Command `ProCmdEditCopy` ;\
mapkey(continued) ~ Command `ProCmdEditPasteSpecial` ;~ Activate `paste_special` `okPB`;
dwg_export_format 2004
intf2d_out_dxf_mapping_file D:\ptc5.0\config\dxf_export.pro
dxf_out_sep_dim_w_breaks NO
intf2d_out_stroke_text ALL
intf2d_out_enhanced_ents SPLINE_AND_HATCH
intf2d_out_acad_mtext NO
intf2d_out_acad_unicode YES
intf2d_out_acad_text_align AS_IS
intf2d_out_pnt_ent YES
intf2d_out_open_log_window YES
use_pre_wildfire_text_font no
ttf_handling_for_plot_files stroke all fonts
weld_ui_standard iso
weld_color 255 171 0
weld_ask_xsec_refs yes
weld_dec_places 0
param_dec_places 2
sketcher_lock_modified_dims yes
pro_font_dir D:\ptc5.0\config\font
save_bitmap_type gif
efx_enabled no
search_path E:\Proe标准件\常用
search_path E:\Proe标准件\齿轮
search_path E:\Proe标准件\紧固件\Assembly
search_path E:\Proe标准件\紧固件\Bolts
search_path E:\Proe标准件\紧固件\Nuts
search_path E:\Proe标准件\紧固件\Pins
search_path E:\Proe标准件\紧固件\Rivets
search_path E:\Proe标准件\紧固件\Screws
search_path E:\Proe标准件\紧固件\Washers
search_path E:\Proe标准件\弹簧
search_path E:\图纸\1练习\PROE
search_path E:\Proe标准件\快速夹头\ch-101-a
search_path E:\Proe标准件\快速夹头\ch-101-b
search_path E:\Proe标准件\快速夹头\ch-101-d
search_path E:\Proe标准件\快速夹头\ch-101-e
search_path E:\Proe标准件\快速夹头\CH-101-EI
search_path E:\Proe标准件\快速夹头\CH-101-EL
search_path E:\Proe标准件\快速夹头\gh-101-d
search_path E:\Proe标准件\快速夹头\GH-101-J
search_path E:\Proe标准件\快速夹头\GH-202-FL
search_path E:\Proe标准件\快速夹头\GH-305EM
search_path E:\Proe标准件\快速夹头\Gh-10247-10250
search_path E:\Proe标准件\快速夹头\gh-12130
search_path E:\Proe标准件\快速夹头\gh-12132
search_path E:\Proe标准件\快速夹头\gh-12205
search_path E:\Proe标准件\快速夹头\gh-20300
search_path E:\Proe标准件\快速夹头\GH-20820
search_path E:\Proe标准件\快速夹头\GH-21383
search_path E:\Proe标准件\快速夹头\gh-22010
search_path E:\Proe标准件\快速夹头\GH-30282
search_path E:\Proe标准件\快速夹头\GH-30290
search_path E:\Proe标准件\快速夹头\GH-30292
search_path E:\Proe标准件\快速夹头\GH-30513
search_path E:\Proe标准件\快速夹头\GH-31501
search_path E:\Proe标准件\快速夹头\GH-36006
search_path E:\Proe标准件\快速夹头\GH-36020
search_path E:\Proe标准件\快速夹头\GH-36060
search_path E:\Proe标准件\快速夹头\GH-36070
search_path E:\Proe标准件\快速夹头\GH-36204
search_path E:\Proe标准件\快速夹头\GH-36330M
search_path E:\Proe标准件\快速夹头\GH-40370
search_path E:\Proe标准件\快速夹头\GH-43150
search_path E:\Proe标准件\快速夹头\GH-43160
 楼主| 发表于 2016-4-22 22:01 | 显示全部楼层
这个是笔画设置
pen 1 color 0.0 0.0 0.0 thickness 0.030 cm
pen 2 color 0.0 0.0 0.0 thickness 0.015 cm
pen 3 color 0.0 0.0 0.0 thickness 0.015 cm
pen 4 color 0.0 0.0 0.0 thickness 0.015 cm
pen 5 color 0.0 0.0 0.0 thickness 0.025 cm
pen 6 color 0.0 0.0 0.0 thickness 0.015 cm
pen 7 color 0.0 0.0 0.0 thickness 0.015 cm
pen 8 color 0.0 0.0 0.0 thickness 0.015 cm
发表于 2016-4-23 09:25 | 显示全部楼层
配置文件内加一项Pen7_line_weight         将值设为1
 楼主| 发表于 2016-4-28 21:59 | 显示全部楼层
大哥你好,按你说的我加入了这个配置项还是没变化,图纸打印出来字体还是很粗,但不包括轮廓线和尺寸界限 ~请问还有别的方法没有?
发表于 2018-6-11 01:11 | 显示全部楼层
5. 0的配置文件可以用到cr
发表于 2018-6-11 01:12 | 显示全部楼层
Croe2. 0
GMT+8, 2025-2-2 10:00 , Processed in 0.150555 second(s), 21 queries .
