查看: 9074|回复: 1
[已解决] Creo illustrate与Arbortext IsoDraw的区别是什么
发表于 2015-10-27 14:56 | 显示全部楼层 |阅读模式
悬赏10金钱已解决
两者都可以做2D,3D技术插图和动画,那具体有什么区别呢?
最佳答案
查看完整内容
Creo Illustrate不是用来“画”2维插图的,它只能加工现有的三维模型,使这些三维图变成可以用到ET目录(我也不知道什么是ET目录)或是产品说明书里的形式,之后导出成各种格式。但是你无法用illustrate画图。而IsoDraw是用来画透视的2维图的。你可以导入三维模型,经调整将其转换成二维图,然后进一步添加新的二维元素。(以下是原文供参考) creo Illustrate is not used for 2D-illustrating. It's "only" for "managing" exist ...
creo Illustrate is not used for 2D-illustrating. It's "only" for "managing" existing 3D models that they are suitable for an ET-catalogue or a user manual. You can then export them in various formats. But: You cannot for example draw any elements in creo illustrate.
IsoDraw is for creating 2D graphics in perspective. You can import 3D models and convert them (after adjustment) into 2D. And then further process.
GMT+8, 2025-4-20 07:38 , Processed in 0.103215 second(s), 21 queries .
