官网配置要求
• Platform Support
• System Requirements
• Language Support
• Graphics Information
• Certified and Supported Graphics Cards
• Supported Peripherals and Accessories
• Supported MCAD Systems
• Supported Finite Element Solvers
• Supported Data Transfer Standards
Platform Support
Partner Platform Operating System levels CPU
Hewlett-Packard
HP-UX (64-bit only) 11iV1 a PA8000 or later
Microsoft
Dell
Fujitsu-Siemens
Hewlett-Packard
IBM
Lenovo
Sun
Windows Vista Business Edition
Windows Vista Ultimate Edition Base OS Intel Pentium/Xeon/Core Duo/Core 2 Duo family
Windows XP Professional x64 Edition Base OS, Service Pack 2 Intel Pentium/Xeon/Core Duo/Core 2 Duo family
AMD Opteron family
Windows XP Professional Edition; Windows XP Home Edition Base OS, Service Pack 1 and 2 Intel Pentium/Xeon/Core Duo/Core 2 Duo family
AMD Opteron family
Sun
Solaris (64-bit only) 8 and 10 UltraSPARC II or later
Solaris (64-bit only) 10 AMD Opteron family
NOTES
a The command "uname -a" returns "HP-UX 11.11"
System Requirements
Windows XP, Vista UNIX
Minimum Recommended Minimum Recommended
Main Memory 256 MB 1024 MB or higher 256 MB 1024 MB or higher
Available Disk Space Pro/ENGINEER 2.0 GB 2.5 GB or higher a 2.5 GB 3.0 GB or higher
Pro/ENGINEER with Pro/ENGINEER Mechanica Wildfire 4.0 2.0 GB 3.0 GB or higher a 3.0 GB or higher 3.5 GB or higher
Swap Space 500 MB 2048 MB or higher 500 MB 2048 MB or higher
CPU speed 500 MHz 2.4 GHz or higher See above table for individual vendor processor support
Internal Browser Support Microsoft Internet Explorer 7.0
Microsoft Internet Explorer 6.0 (SP1 or later) Browser (Mozilla 1.7.8) is embedded in Pro/Engineer on UNIX platform
Monitor 1024 x 768 (or higher) resolution support with 24-bit or greater color 1024 x 768 (or higher) resolution support with 24-bit or greater color
Network Microsoft TCP/IP Ethernet Network Adapter TCP/IP Ethernet Network Adapter
Mouse Microsoft-approved 3-button mouse 3-button mouse
File systems NTFS All vendor-supported file systems.
Misc. CD-ROM or DVD drive CD ROM or DVD drive
NOTES
a For Windows XP only. For 32-bit operating systems, the Windows limit is 2.0GB. For Windows XP you must enable the /3GB switch in order to utilize RAM greater than 2.0GB.
Language Support
Supported Language Date Certified Release Datecode Comments
English 13-Jun-2007 C000
Chinese Simplified 13-Jun-2007 C000
Chinese Traditional F000 Will be available with the production shipment of Pro/ENGINEER Wildfire 4.0 in early 2008.
French F000 Will be available with the production shipment of Pro/ENGINEER Wildfire 4.0 in early 2008.
German 13-Jun-2007 C000
Italian F000 Will be available with the production shipment of Pro/ENGINEER Wildfire 4.0 in early 2008.
Korean F000 Will be available with the production shipment of Pro/ENGINEER Wildfire 4.0 in early 2008.
Japanese 13-Jun-2007 C000
Spanish F000 Will be available with the production shipment of Pro/ENGINEER Wildfire 4.0 in early 2008.
NOTES
For more detailed information on localization for this product, please click here.
For 3D-hardware acceleration, an OpenGL graphics card must be used that has been tested in a PTC-certified configuration. To ensure the compatibility of a graphics driver with Pro/ENGINEER Wildfire 4.0, a PTC-certified hardware configuration is recommended.
Dual Monitor Support
Limited dual monitor support is provided in Pro/ENGINEER Wildfire 4.0 on the Windows platform. PTC has successfully performed limited testing of some graphics card models from 3DLabs, ATI and NVIDIA that support dual monitor capabilities. If your graphics card is certified for Pro/ENGINEER Wildfire 4.0 and provides dual monitor support**, PTC expects that it will run in this mode without issue. PTC will provide limited support to resolve issues arising when running in dual monitor mode, however, the entire solution will not be submitted for formal certification as a complete configuration.
Note: in the event that dual monitor mode fails, we advise use of Span mode as a workaround.
**Please consult with AMD, NVIDIA, or the hardware platform partner to confirm the availability of this functionality with a given graphics card that has been certified with Pro/ENGINEER Wildfire 4.0.
PTC provides Customer Support for all certified and/or supported graphics cards. Certified cards will be added to this table as our platform partners complete certifications in preparation for production shipment of Wildfire 4.0.
Please note that the table below represents graphics cards that are part of a fully-certified or supported configuration (e.g., machine, model, operating system, graphics card and driver). PTC does not certify or support graphic cards independently from the configurations in which they are certified or supported. Please consult the linked partner pages for specific configurations.
Partner Certified Graphics Cards Certification Details Supported Graphics Cards Support Details
AMD (ATI) FireGL V7300 Fujitsu-Siemens
FireGL V7200 Dell, HP
FireGL V5250 Lenovo
FireGL V5200 Fujitsu-Siemens, HP, Lenovo
FireGL V3400 Dell, HP
FireGL V3300 HP
NVIDIA Quadro FX5500 HP, Sun
Quadro FX4600 Dell
Quadro FX4500 Dell, HP, Sun
Quadro FX3500 Dell, Fujitsu-Siemens, HP, Sun
Quadro FX3450 HP, Sun
Quadro FX3400 Dell, HP
Quadro FX3000 Sun
Quadro FX2500 Dell
Quadro FX1500M HP
Quadro FX1500 Dell, Fujitsu-Siemens, HP
Quadro FX1400 HP, Sun
Quadro FX1100 Sun
Quadro FX560 HP
Quadro FX550 Dell
Quadro FX540 HP, Sun
Sun XVR-1200 Sun
Windows (XP, XP x64, Vista) Sun Solaris HP-UX
3D Controllers (Pro/ENGINEER only) Please refer to http://www.3dconnexion.com/software/ for specific driver information.
SpaceTraveler Certified
Certified
Certified
SpaceBall 5000 Certified
Certified
Certified
Plotters and Printers
Pro/ENGINEER supports HPGL, HPGL/2, PostScript, Calcomp, Gerber and Versatec standard plotting formats. In addition, Pro/ENGINEER supports the Microsoft Print Manager.
If you do not see your printer/plotter on the list below, please refer to the Introduction and Support Policy .
Emulation
Various manufacturers produce printers and plotters that may be compatible with or emulate a device that is supported by PTC. Please be aware that such devices are not tested by PTC and therefore, may not produce correct plotted output. If you are using a device which emulates a printer or plotter listed in the tables below, PTC Technical Support will attempt to provide support by using a similar certified device. Any support pertaining to compatibility with a supported plotter or the correctness of an emulation can only be made by the manufacturers of the device in question, and not by PTC.
The Microsoft Printer Manager creates an emulation of what appears on the screen and attempts to print this. Since this emulation is between the Print Manager driver and the printer/plotter driver, quality and results may vary. You may choose to try a certified PTC printer/plotter driver, which has been optimized for high quality printing.
Plotters
Windows XP Sun Solaris HP-UX
HP Designjet 1055CM+ Certified
Certified
Certified
HP Designjet 800PS Certified
Certified
Certified
HP Designjet 5500PS Certified
Certified
Certified
HP Designjet copier cc800PS Certified
Certified
Certified
HP Designjet 4000 Certified
Certified
Certified
Printers
HP deskjet 1220cps Certified
Certified
Certified
HP color inkjet cp1700ps Certified
Certified
Certified
HP business inkjet 2600dn Certified
Certified
Certified
You can integrate several MCAD systems with Pro/ENGINEER Mechanica Wildfire 4.0. The following table lists the supported MCAD systems and platforms.
Platforms CATIA Release 4.2.4 (English only) Unigraphics Release NX 3.0 (English only)
HP (64 bit) x x
Intel-based PC (Windows XP) x
Sun (64 bit) x
NOTES
You can integrate several Finite Element Solvers with Pro/ENGINEER Mechanica Wildfire 4.0 for use in FEM mode. The following table lists the supported Finite Element Solvers and platforms.
Platforms NASTRAN 2005 r2 ANSYS 10.0
HP (64 bit) x x
Intel-based PC (Windows XP) x x
Sun (64 bit) x x
NOTES
Pro/ENGINEER Mechanica Wildfire 4.0 supports the following standards for transferring data to and from MCAD programs:
Platform DXF 13.0 IGES 5.2 VDA 2.0
HP ( 64 bit) x x x
Sun ( 64 bit) x x x
