查看: 6943|回复: 4
[已解决] 关系式表达什么意义?
发表于 2015-3-23 09:06 | 显示全部楼层 |阅读模式
悬赏10金钱已解决
某前辈的钣金零件模型里的关系式,有很多的IF语句,有的不明白,特求助翻译表达意义。谢谢
CTYPE="零件"  /*模型类型
T=SMT_THICKNESS
I=floor(T,0)
F=T-I
if I==0
I1="0"
else
I1=itos(I)
endif
if F==0
TH="/T="+I1+".0"
else
TH="/T="+I1+"."+itos(F*10)
endif
if DWGNAME==""||DWGNAME==" "|DWGNAME=="  "||DWGNAME=="   "||DWGNAME=="    "||DWGNAME=="     "
DWGNAME=MODELNAME
TEMPNAME=MODELNAME
FNAME=PTC_COMMON_NAME
else
if FNAME!=PTC_COMMON_NAME
DWGNAME=""
CNAME=""
CNOTE=""
PTC_COMMON_NAME=MODELNAME
else
if TEMPNAME!=MODELNAME&&DWGNAME==TEMPNAME
DWGNAME=MODELNAME
TEMPNAME=MODELNAME
FNAME=MODELNAME
endif
endif
endif
if CMAT==""||CMAT==" "||CMAT=="  "||CMAT=="   "||CMAT=="    "||CMAT=="     "
CMATERIAL=PTC_MATERIAL_NAME
if PTC_MATERIAL_NAME!="请选择材料"&&PTC_MATERIAL_NAME!=" "
CMATERIAL=PTC_MATERIAL_NAME+TH
endif
else
CMATERIAL=CMAT
endif
sheet_design.prt.zip
35.35 KB, 下载次数: 19
 楼主| 发表于 2015-3-23 12:01 | 显示全部楼层
没人懂吗?不会吧
 楼主| 发表于 2015-3-23 20:01 | 显示全部楼层
谢谢你的解答,这其什么作用呢?
发表于 2019-9-5 09:56 | 显示全部楼层
没加注释的,都是耍流氓
GMT+8, 2025-2-1 22:45 , Processed in 0.127782 second(s), 23 queries .
