查看: 45188|回复: 68
[分享] proe 野火3.0 M080 注册机下载和安装破解说明
发表于 2007-10-8 20:39 | 显示全部楼层 |阅读模式
.boot up your pc with windows
.start pro/e setup
.open ptc_licfile.dat with your fav txt-editor
.replace every occurance of <HOSTID> with the one shown in the bottom left corner of the Pro/e setup
(its your mac-id, format: xx-xx-xx-xx-xx)
.install pro/e - pro/m - pro/ds, i dont care which one or in which order
.on license-config screen select "nodelocked license" and point to edited ptc_licfile.dat
.blalala install
next for pro/engineer:
(if u didnt install the complete package, u get "missing file" errors, accept or bleed)
.run ptc.pro engineer.wildfire.3.0.generic-patch.exe, point to <installdir>\i486_nt\obj folder
.edit <pro/e installdir>\bin\proev.bat
  change "%start_cmd% "%CGTECH_JRE%\bin\javaw" -Xms16m -Xmx64m -Xss4m -classpath "%CGTECH_CLASSES%;%CGTECH_CLASSES%\CGTech.jar" Vericut %argstr%" in
        "%start_cmd% "%CGTECH_JRE%\bin\javaw" -Xms16m -Xmx64m -Xss4m -classpath "%CGTECH_CLASSES%;%CGTECH_CLASSES%\CGTech.jar" Vericut %argstr% PTC_KEY=0"
(add PTC_KEY=0)
pro/mechanica:
.run ptc.distributed.services.generic-patch.exe
.point to <pro/m installdir>\i486_nt\bin
                                         <pro/m installdir>\i486_nt\obj
                                         <pro/m installdir>\i486_nt\ptc
(in this order, after every "missing file" error)
pro/distributed services:
.run ptc.distributed.services.generic-patch.exe and point to <pro/ds installdir>\i486_nt\obj
PROE M080 注册机.rar
25.93 KB, 下载次数: 4854
发表于 2007-10-19 14:28 | 显示全部楼层
能不能有祥细安装说明,贴上图片就更好,谢谢
 楼主| 发表于 2007-10-19 16:33 | 显示全部楼层
回楼上,可以参考相近版本的图片教程,论坛都有,安装过程多是相同的
发表于 2007-10-28 05:43 | 显示全部楼层
是呀给电图片
谢谢
发表于 2007-10-29 10:38 | 显示全部楼层
大家 好
发表于 2007-11-9 20:53 | 显示全部楼层
怎的全是英文呀
发表于 2007-12-2 20:26 | 显示全部楼层
发表于 2007-12-4 23:05 | 显示全部楼层
謝謝了,我在網上找了很久了。
沒想到,遠在天邊,近在眼前
发表于 2007-12-26 13:09 | 显示全部楼层
到底怎样才能下载到东东啊
发表于 2008-1-9 19:50 | 显示全部楼层
回复 楼主 的帖子
谢谢,是否有汉化的说明啊
GMT+8, 2024-9-28 21:21 , Processed in 0.151347 second(s), 25 queries .
