查看: 15558|回复: 3
[求助] creo2.0安装好后不能正常启动一闪而过
发表于 2013-2-5 10:32 | 显示全部楼层 |阅读模式
creo2.0安装好后不能正常启动一闪而过请问是怎么回事??????急急急!!!!!!!
老冯
发表于 2013-2-5 10:49 | 显示全部楼层
置顶“Pro/E Wildfire 下载、安装、常见问题索引”,有4.0出现你这种情况的解决方法,可以参考下
http://www.proewildfire.cn/thread-25165-1-1.html
发表于 2013-2-5 21:32 | 显示全部楼层
我的现象和他的一样,安完一闪没了,我安的是creo2.0 m020; 重做的XP正版系统
Parametric.psf内容如下:
DESC=Creo Parametric (default)
SHIPCODE=M020
CREO_COMMON_FILES=Common Files\M020
ENV=MECH_LP=%PRO_DIRECTORY%\mech
ENV=MECH_HOME=%MECH_LP%\%PRO_MACHINE_TYPE%
ENV=PRO_MECH_COMMAND="%CREOAPP_DIRECTORY%\bin\parametric.exe" "%CREOAPP_DIRECTORY%\bin\parametric.psf"
ENV=RPC_TIMEOUT=31536000
ENV=MEDI_HOME=%MECH_HOME%
ENV=PATH+=%PRO_DIRECTORY%\%PRO_MACHINE_TYPE%\deflib
ENV=PATH-=%PRO_DIRECTORY%\%PRO_MACHINE_TYPE%\lib
ENV=PATH-=%INTRALINK_DIR%\%PRO_MACHINE_TYPE%\illib
ENV=PATH+=%PRO_DIRECTORY%\libs\dfor\lib
ENV=NMSD_TIMEOUT=300
ENV=PRO_COMM_MSG_EXE=%PRO_DIRECTORY%\%PRO_MACHINE_TYPE%\obj\pro_comm_msg.exe
ENV=PROE_START=%CREOAPP_DIRECTORY%\bin\parametric.exe
ENV=CDRS_DATA=%PRO_DIRECTORY%
ENV=PRO_IMAGE_CONVERTER=%PRO_DIRECTORY%\%PRO_MACHINE_TYPE%\obj\convert_image.exe
ENV=PROGUIDE_DIRECTORY=%PRO_DIRECTORY%\uifdoc
ENV=SPG_DIRECTORY=%PRO_DIRECTORY%
ENV=PRO_USRMAIN=%PRO_DIRECTORY%\usrprog\umain\usrmain.c
ENV=PROTABLE_DIRECTORY=%PRO_DIRECTORY%\protable
ENV=MOZILLA_FIVE_HOME=%PRO_DIRECTORY%\%PRO_MACHINE_TYPE%\obj\MOZILLA
ENV=PROTAB=%PRO_DIRECTORY%\%PRO_MACHINE_TYPE%\obj\protab.exe
ENV=ZIP_EXEC=%PRO_DIRECTORY%\%PRO_MACHINE_TYPE%\obj\zip.exe
ENV=CLHOME=%PRO_DIRECTORY%\text\pcldata
ENV=PVIEW_PROEPVIEW_HOME=%PRO_DIRECTORY%\apps\prodview
ENV=CV_ENV_HOME=%PRO_DIRECTORY%\%PRO_MACHINE_TYPE%\CV140
ENV=DEBUG_HLP_DLL_PATH=%PRO_DIRECTORY%\%PRO_MACHINE_TYPE%\lib\dbghelp.dll
ENV=PTC_D_LICENSE_FILE-=C:\PTC\Crackptc_licfile.dat
ENV=CREO_APP=PMA
ENV=CREOPMA_FEATURE_NAME=CREOPMA_SSQ PROE_SSQ ()
RUN="%MECH_LP%\install\nt\pro_mech_env.bat"
RUN="%PRO_DIRECTORY%\%PRO_MACHINE_TYPE%\nms\nmsd.exe" -noservice -timeout %NMSD_TIMEOUT% &
RUN="%PRO_DIRECTORY%\%PRO_MACHINE_TYPE%\obj\xtop.exe"
// USER - PSF
// Add User specific environment or run applications below here
ENV=DBG_NCPOST_PATH=%CREOAPP_DIRECTORY%\bin
trail.txt.1内容如下:
!trail file version No. 1600
!Creo  TM  2.0  (c) 2013 by Parametric Technology Corporation  All Rights Reserved.
!Exit Logger data:
!        Process ID: 2528
!        Application: Creo_Parametric
!        Start date&time: 2013/02/05  21:02:56
!        language: chinese_cn
!        machine type: i486_nt
!        datecode: M020
!        Server: NONE
!        Workspace: NONE
!        traceback file: C:\PTC\Creo 2.0\Parametric\bin\traceback.log
!end Exit Logger data.
! Message Dialog: Warning
!mem_use INCREASE Blocks 443831, AppSize 38034174, SysSize 48883088
!               : 遇到严重错误。已将回溯写入
!               : C:\PTC\Creo 2.0\Parametric\bin\traceback.log
!               : 请将其发送给“技术支持”。
我应该改那?急!
发表于 2013-2-6 08:08 | 显示全部楼层
这看着连这个问题都解决不了,真心郁闷!!!就这还敢玩CREO!?
人,一定要靠自己!
GMT+8, 2025-4-30 10:15 , Processed in 0.196529 second(s), 22 queries .
