查看: 3704|回复: 0
[求助] 关于Pro/e转CAD线性,颜色,图层的配置文件无效
发表于 2012-10-24 18:32 | 显示全部楼层 |阅读模式
不知道什么原因,转换是 还是默认配置,请大神看下到底是哪里的问题
hamfer_45deg_dim_text iso/din
drawing_setup_file $PRO_DIRECTORY\text\iso.dtl
format_setup_file $PRO_DIRECTORY\text\iso.dtl
pro_unit_length unit_mm
pro_unit_mass unit_kilogram
template_designasm $PRO_DIRECTORY\templates\mmns_asm_design.asm
template_drawing $PRO_DIRECTORY\templates\a3_drawing.drw
template_sheetmetalpart $PRO_DIRECTORY\templates\mmns_part_sheetmetal.prt
template_solidpart $PRO_DIRECTORY\templates\mmns_part_solid.prt
todays_date_note_format %dd-%Mmm-%yy
tolerance_standard iso
tol_mode nominal
weld_ui_standard iso
pro_library_dir E:\ProLibs\
pro_catalog_dir E:\ProLibs\
pro_symbol_dir C:\Program Files\proeWildfire 5.0\formats\PTCWORK\symlib
default_draw_scale 1:1
tol_display yes
intf_out_layer part_layer
intf2d_out_dxf_mapping_file D:\proedata\dxf_export
trail_dir d:\proetemp
startup_check_for_visualization no
pro_format_dir C:\Program Files\proeWildfire 5.0\formats\
bom_format C:\Program Files\proeWildfire 5.0\symbols\report\bomballoon\b_left.sym
menu_translation yes
pro_editor_command C:\windows\notepad.exe
pen_table_file D:\proedata\table.pnt
use_8_plotter_pens yes
ap_layer   DXF_DIMENSION          1
map_layer   DXF_TEXT               Text
map_layer   DXF_HATCHING           Hatch
map_layer   DXF_TABLE              Table
map_layer   DXF_BALLOON            Balloon
map_layer   DXF_FORMAT             Format
map_line_style  solidfont          bylayer
map_line_style  phantomfont        CENTER
map_line_style  ctrlfont           CENTER
map_line_style  bylayerfont        Hidden
map_line_style  dashfont           Hidden
map_line_style  ctrlfont_s_l       Hidden
map_line_style  ctrlfont_s_s       Hidden
map_line_style  ctrlfont_l_l       Hidden
map_line_style  dashfont_s_s       Hidden
map_line_style phantomfont_s_s     Hidden
map_line_style ctrlfont_mid_l      Hidden
map_line_style  CONTINUOUS         CENTER
map_layer Dxf_dimension_dim
配置文件.zip
1.83 KB, 下载次数: 7
GMT+8, 2025-2-19 06:05 , Processed in 0.144780 second(s), 24 queries .
